ground wires on the block?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i keep being referred to the cylinder block bolt connecting grounds for most of my electrical system.
ive been told is on my driverside in the back.
theres sooo many wires and stuff in the way how far down in the back is it?
how did you guys find it?
i have a 305 tpi v8 5.0 1986 trans am
Re: ground wires on the block?
Mine is just below the head and is a stud which sticks out about an inch.It is tight right there and it is only about an inch away from the fire wall. Look with a flash light. Good luck
eightsixseven
08-14-2015 03:09 PM
