Correct spark plugs to iron headed L98
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I have ac delco 41-629's are they the correct plug for my iron headed L98? I'm not actually running L98 heads I'm running 3947041's which are an older early 70's casting but I'm assuming they would take the same plugs... The reason I'm askin this question is because the delco's I just got are about a half inch longer than the plugs I'm taking out, but I'm not sure if the old plugs were the right ones to begin with.. Can anyone enlighten me?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Correct spark plugs to iron headed L98
The R45TS is the stock spec plug for most 3rd gens IIRC.
The S refers to extended tip, so I think, if you want, you can use R45T so it's the same length as what you pulled out of the 041 heads.
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
02-28-2016 03:33 PM
eightsixseven
08-14-2015 03:09 PM
