Loud Tapping...
Car: Pair of 92 Z28s
Loud Tapping...
Well my gf calls a little before 9 tonight, said she was pulling off the highway and it starting tapping real bad. Told her to pull over turn it off and id be there soon. So i get there i check it out. Oil looks ok, Oil Pressure ok. Start it up, loud tapping from the driver side head. Sounded like a bad exhaust leak at first like a cracked manifold but i couldnt really see/smell/feel it leaking from the manifold. Well i had enough tools to pull the valve cover partially off. Started it up, it was dark all i could see with the light were the springs, i couldnt see the pushrods on the other side. They seems like they were functioning fine but then again couldnt really get a good look. Sounds like a clear tapping from either the #5 or #7 cylinder. Anyway i decided to drive it back to her house and she follow me in my truck. Its only loud when you get over 2k rpms.
Anyway tommaro ill be pulling off the valve cover, anything i should be notice off hand when its off thats normal / not normal?
Collapsed Lifter, Bent pushrod, Spring binded? How should i go about diagnosing this?
Thanks guys for any help.
Also its for a 89 RS 305 TBI.
-Steve
-Steve
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: Loud Tapping...
I have the same problem with my GTA. But, it only gets that tapping sound when it warms up, not when it is cold. Sorry for this post, just trying to kill two birds with one stone.
Re: Loud Tapping...
No i couldnt get it to clear the fuel lines, had it up off a few inches, maybe i could but i didnt have **** for light or tools. It definently sounds up top and by the speed of the tapping of it nothing like a rod or main bearing.
luvofjah
09-26-2015 08:28 PM
