Do I need Self-Aligning Rockers?
Car: 86 Iroc Z28
Engine: 350 5.7L (rebuilding now)
Transmission: 700R4 shift kit
Axle/Gears: 3.73, 9-Bolt, stock posi
I had purchased a set of Comp. Cams Pro Magnum roller rockers, 1.5 ratio. I have been rebuilding my engine and had a local mechanic friend come over to inspect some of the work I'd done. He said everything looked great with one exception. He felt that I needed to use the self-aligning roller rockers since the top of the valve set so much higher than the top of the spring. The springs can handle a lift up to 600.
The engine is a ZZ4 build. It's an 87 350, 60 over, zz4 cam, 113 casting aluminum heads, tpis big-mouth intake, large tube runners, flat top hypereutectic pistons. EDIT: Also, the heads have guideplates installed.
Any advice on this would be greatly appreciated. If I need to get the self-aligning rockers, I need to get them quickly as I was going to install the engine this weekend.
Thanks for any and all help,
Pat
Pat
Car: 86 Iroc Z28
Re: Do I need Self-Aligning Rockers?
Bump. Anyone have any ideas? I thought that with guideplates, you didn't need self-aligning roller rockers. But the guy that looked at it said he would be worried that they would slip off the side and throw a pushrod. There is some movement side to side, but it just seemed a little extreme to me.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I have no idea what he's talking about, and possibly he doesn't either.. If you have guide plates, you want non-self-aligning rockers.
Car: 86 Iroc Z28
Ok, that is good news. The guide plates are installed under the screw-in studs and it all looks good to me.
Should there be some side to side movement? That was the concern he posed.
Thanks,
Pat
Thanks,
Pat
Engine: 383 Carb
Transmission: 4L60
Yes, there will be a very small amount of sideplay regardless of what method is used to locate the rockers.
Car: 86 Iroc Z28
Ok, thank you very much for all the info and advice!
Thanks again,
Pat
Thanks again,
Pat
Guest
Posts: n/a
With guideplates, no you dont need nor want self aligning rockers. I gotta ask though... are those aftermarket guideplates? The GM ones that came on some corvette AL heads arent compatible with hardened pushrods. FYI.
Car: 86 Iroc Z28
Well they are the GM guideplates, so it looks like all I need to do is get a set of aftermarket guide plates and all will be fine. I'm glad you mentioned about the guideplates, that was something that would have caused me a bunch of trouble!!
Thanks everyone for all the help! I really appreciate it!
Pat
Pat
Car: 86 Iroc Z28
Well, I've got the hardened push rods, and after looking up the info for the head, it states that it uses the rail-type rockers with the gm plates, or you can use non-rail type rockers and change the guide plates.
Do you really think I can use the existing guide plates??
Received 1,863 Likes
Car: 86 Iroc Z28
I'm didn't describe it very well, but that is what I was trying to say. But it said to replace the existing guide plates if I was going to use non-rail type rockers.
My whole concern here is that I don't want to get it all assembled and then have to redo all the work I've done so far. I'm assuming that if it's calling to replace the existing guide plates if using hardened push rods, that maybe it would grind on the GM guide plates and create some filings which I don't want floating around in the engine!
Does that make any sense??
Thanks,
Pat
Thanks,
Pat
Car: 1989 IROC
Engine: L98 350
Axle/Gears: 3.45 posi 1LE
madmax----I just read your post and now I'm worried about my engine work recently done. I have an original 5.7 350 engine in my 89 IROC with 92K miles on it. Two months ago, a local Corvette and Camaro auto shop installed Chrome Moly pushrods in my stock motor, along with Comp Cams Magnum 1.5 Roller Rockers (part # COM-1417-16) and new cam, XR 264 (part # 08-501-8). I put about 2,000 miles on my Camaro already. Am I going to have problems with this set up?
Car: 86 Iroc Z28
Ok, I have one last question, the current guide plates are flat and are obviously what I will follow with. Is there a certain size I need to get with my comp cams pushrods? I would assume that there are some larger width cutouts in the guideplates. I'm sure this is a pretty noob question, but I really don't know.
Thanks,
Pat
Thanks,
Pat
Car: 86 Iroc Z28
bump...
Car: 86 Iroc Z28
Ok, great! Thanks a bunch!! I appreciate it and that does make sense!
New2Chevy
09-28-2015 12:35 AM
