Burnout for nooby me!
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Don't make fun of me, but I've never done a burnout... yet!
So I heard with RWD you need to feather the brakes. Is this true?
Explain...
-Thanks, peace out!
Explain...
-Thanks, peace out!
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Re: Burnout for nooby me!
auto you can brake torque you car hold your brake in untill ur wheels start spining then you can slowly let off
manual you can dump the clutch not a some super high rpm or you will be one un happy camper
Car: '92 Camaro Z28
Brake Torque - I hold my brake with gas and slowly let off the brake until my tires spin?
If that's what your explaining, I think I got it..
Car: 84 trans am
Transmission: built 700r4
yeah you got it, just stop and with your foot on the brake hit the gas and the tires will start spinning, you can adjust weather your moving or standing still and how fast your wheels spin by changeing brakeing pressure and if needed changing throttle and sometime gears.
if your just doing a burnout on the street thats all you need to know, but if this is for at the track there are a lot more rules to go by, like dont go in the waterbox if you have street tires it wont help you at all. an if you are useing slicks when exiting the box try not to just let off the gas realy quick coming out or you will shock the trans when the tires hook realy quick
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well on friday he is going to test and tune night and doesnt want to look silly in the water box...
Car: 84 trans am
then dont go in the water box. or you will just look stupid
btw what part of pa are you guys from? i just have that feeling that your talking about going to maple grove
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
for BEST results and for the regular racer, get a line lock.. no burned rear brakes and no extra load on the trans.. and like everyone else says, with street tires, dont touch the water.. if you do, you better spin the tires fast enough to get the water out of the thread grooves.. for me and my drag radials, 6k in second(about 60mph) gets the job done..
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Street tires at the track: Stay out of the water. Reports vary on the effectiveness of burnouts with street tires - conventional wisdom on this Board says just turn them enough to clean off the tread, Tony Pedregon says "Light 'em up!" ( https://www.thirdgen.org/forums/orga...-burnouts.html )
Car: '92 Camaro Z28
Well thanks for the info about the track, but i'm all street right now... lol
-Thanks
-Thanks
Car: 89 RS
Transmission: th350
Its not good to powerbrake the car. What i usuraly do is hold the brake and stomp the gas and let off the brake. Even my wornout 305 car will leave 2 sollid black marks.
Car: '92 Camaro Z28
What happens when you powerbrake the car?
Car: 89 RS
Transmission: th350
It is hard on the transmission, rearend and rear brakes. If you have posi it will also wear out the clutches in the posi. If you have a good running motor then you should be able to stomp it and spin them prety good.
Car: 1984 Trans Am
Click here to see Video
Car: '82 Z28
Dangit, you're making me want to do a new video of mine on the street.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
haha, i've gotta get a digital camera... Mine will burn 'em in 2nd gear (first is wayyyy too short), but I'm not sure from a complete stop... Gotta tweak the carb some.
But yea, a burnout is just punching it from a stop.
A brakestand is when you use the brakes to do it.
At the track, you'll want to do a brief brakestand, in front of the waterbox, just to clean off the tires.
A TPI 305 in decent running condition should have no problem doing that.
Abubaca
11-05-2016 12:22 PM
