cooler spark plugs
cooler spark plugs
im running nitrous on my car this summer so i was looking to find a cooler heat range of spark plugs. but when i look them up and find the heat range its all diffrent letters and numbers like C 5 9 8 D 4 2, so how do i tell what the stock heat range is and whats a heat range cooler?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Received 1,718 Likes
Re: cooler spark plugs
Your plugs are some number like R45TS.
R = resistor
45 = the heat range
T = tapered seat
S = extended nose
lower number = cooler
In the example above, you might try R43TS for a cooler but otherwise identical plug.
R = resistor
45 = the heat range
T = tapered seat
S = extended nose
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Sofas right there for delco. I've attached a chart for delco and NGK. NGK is UR4 for the hot one, UR5 cooler, UR6 cold.
Champions equivalent to the R45TS is the RV17YC
The equivalent to the cooler R42T (non extended nose as well) is RV8C
So for champion
RV (heat range)8 (if you want the extended nose, Y) C
I like champion because they are silver, vs delcos black oxide. The silver is easier to read than the black IMHO.
So for champion
Car: 89 Bird 93 Old Cutlass Ciera
Engine: 305/ 3.8 S.C.
Transmission: 700r4 and IDK
Axle/Gears: ????????
The R42's are great heck for the price i would run em. I think that is what you want if not a step colder with the right amount of timing. let me know what the timing is set at and what size shot you are shooting. War Eagle Racing
Car: 1982 Trans-Am
The 42's should be fine. I run a R42T (no S). On f-birds recommendation. I can't tell you why (lest I have to kill you).
Stock motor otherwise? Ie, no other reason to go to a colder plug as well?
You should be able to get those at your local parts shop for cheaper than that as well.
