Headbolts cleaning - 7/16x14 die ?
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
7/16x14 NC die is the one you use to clean the bolts, right ? In order to clean them up, by removing the old sealant.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Headbolts cleaning - 7/16x14 die ?
Yep. Cleaning/thread chasing tap works, or an el cheapo normal tap.
EDIT - I thought you meant the holes. The bolts themselves, yes the die. Or just use a wire brush wheel on a bench mounted grinder. THAT makes short work of them. You'll just get your die all gunky. Use head bolt washers on reinstall, MRG makes them.
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
yep sounds good, i would run the bolts in a die, and use an electric impact wrench to run them up and down several times
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
an electric impact? can you say over kill i would say by hand unless you are a little on the wimpy side
its slow to do them by hand, but i wouldnt every try to thread a bolt using an electric impact, just to clean up the threads
Car: 1991 Camaro RS
Engine: LO3
That's exactly WHY I asked, since I started doing one of them, and it's really tough work, so I had to make sure I was using the right tool and the right size.
I don't know where I put my wire wheel so, ok.. thanks guys
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I always used a wire wheel chucked in my electric drill. Most hardware stores carry them in different diameters.
I first clamp the bolt in my bench vise held by the head. Zip-Zip; done deal.
Jake
Jake
Car: 1991 Camaro RS
Engine: LO3
Yeah I managed to find my drill mounted small wire wheel, but the one I used the die on still looks better. Heck I'm to the point where I'm considering just buying new head bolts, but I don't feel like spending 35-50 bucks, minimum, on just .. bolts
Car: 91 RS
Engine: 350 vortec
if your doing anything other than a stock rebuild i would get so new bolts from ARP they would be worth it well to me they would be
Car: 1991 Camaro RS
Engine: LO3
This is simply a stock rebuild (everything minus bearings and piston rings), because my car broke down, turned out to be the flexplate to torque converter bolt flying out and jamming the starter, however the engine was burning oil anyway and it looks like there was blow-by as well.
I'm using my buddy's old engine for the rebuild, my old one well I'll probably do some serious work to that one, since I may do a TPI swap and supercharge it.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i use a wire wheel on a bench grinder.. takes all of 15 seconds each and cleans EVERYTHING OFF..
Car: 1991 Camaro RS
Engine: LO3
Unfortunately I can't find my bench grinder wire wheel, so I'm using my drill mounted one. Takes a bit longer than 15 seconds but oh well. For the next build I may go and use an impact wrench and the die.
