too much seat pressure for hyd flat tappet cam?
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
OK, i got the afr 210 race heads p/n 1050. they come with roller springs with these specs; installed height 1.9" at 144 lbs. open, 426lbs at .650, 396lbs at .600, 370lbs at .550 im thinking these are going to be too much for a hyd flat tappet cam with lifts in the .580 range. Anyone have some input on if these will work or what springs i should change to? thanks
Received 1,862 Likes
Re: too much seat pressure for hyd flat tappet cam?
For racing only, they're probably OK. For street use, too much.
They're probably too much for break-in, regardless of the usage. This would be a DEFINITE case of needing to remove the inners for the first half-hour or hour of operation, which would need to be at moderate RPMs (2000-4000 or so).
Check with the cam mfr; they're the ones that will, or won't, warranty the cam. Whatever we say here has no standing with them.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
AFR 210 race heads, with .580" lift HYDRAULIC flat tappet cam? Why not a solid flat tappet?
Car: 91 z28
i dont know why, mainly because its more of a set it and forget it, im trying to keep it simple, if i decide to go solid flat tappet, am i going to be able to keep the springs i have or get new ones either way?
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
hydraulic flat with Afr 210's?!?! you should be going roller with heads like that.. or at least a big solid flat tappet.. pressures do seem kinda high.. i would try get it down to 130ish seat pressure..
Compare them with the specs on the springs that are recommended for use with that cam by the manufacturer. I bet it will be more like 120-130 on the seat and in the low 300s over the nose. Yes, they sound like a bit much for a flat tappet hydraulic run on the street.
Car: 1982 Trans-Am
I'm just thinking that with those big heads, and the large lift cam, you'll need to rev it up kinda high to get into your power band. Floating hydraulic lifters really sucks. You have too big of a cam to have low end, and hydraulic lifters float so you have no high end. Worst of both worlds
At least that *could* happen.
That's why I was thinking solid flat. That should be enough spring for a solid flat tappet of roughly the same size. Like Damon said see what the cam manufacturer says. You shouldn't have to relash the valves more than once an oil change anyway, not a big hassle IMHO.
Car: 1984 Trans Am
Car: 91 z28
ok i guess ill go with a solid flat tappet cam, i would go with roller, but the shortblock is already assembled and the block work is done, i was going to go with the 195's but i figure if i get the 210's now i wont have to buy better heads in later builds (looking to do f series procharger and more cubes next) thanks for all the input guys, ill just get the recommended springs from the manufacturer, also i guess i had the misconception of the amount of adjustments associated with solid cams, once every 3k+ miles will take a long time driving under 100 miles a month lol
Car: 1988 Trans Am GTA
Engine: 350 4BBL
With a .580 lift, he's building for the track anyway...
Car: 91 z28
its my weekend car club cruiser, it will see a lot of track time as well, but i would think the duration has more to do with it than the lift as far as streeetability...i've seen MUCH larger cams in very streetable cars.
With ANY flat-tappet cam, hyd or solid, you'll need to remove the inner springs for break-in.
Once that is done and the lifters are successfully observed to rotate like they're supposed to, you can put the inners back.
Car: 1982 Trans-Am
For non-roller cams, non-stock hydraulic lifters will work to the 7000-7500 range. This is past streetable in my OHpinion. My rule of thumb: If it's going to be driven on the street, it can use hydraulic lifters.
Either way, since you said 100 miles a month (which is about what I assumed with such a radical type of build anyway, probably not a DD), I still think you'd be happier with a solid cam. It's an additional tuning device as well, you can always set the lash a bit wide and tame the cam a bit, etc.
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Just to add some personal experience. I broke a roller SBC I built so I threw the heads as they were on to a flat tappet SBC. This equaled a flat cam in about a year.
The heads were 200 ETEC. THe springs were a double Crane design at about 425 Lbs/in. The Cam was a COMP cam flat tappet hydraulic extreme marine series. Lift in the .510 area with 1.6 rockers and duration in the 220 area.
My opinion step up to a retrofit roller set up of get some matched springs. Save lots of grief. Got some pics if your interested
Car: 91 z28
well that means new cam bearings too, so i'd have to tear the motor down...not to mention 400+ for a set of retrofit roller lifters and a 250+ for a cam...... ill just go with a new set of springs for around $150 and go with solid flat tappet cam
Car: 1982 Trans-Am
Post up the cam you think you'll go with. I'm curious what you're thinking about. Sticking with the nitrous on this motor?
Remove the roller springs and get the recomended spring to match your Flat tappet cam reguardless of the final choice.
They are just way too much spring for a any flat tappet cam.
You could either sell them off to recover the cost or save them for another project.
Car: 91 z28
i thought roller cams used differnt cam bearings? maybe i was wrong....
Car: 1982 Trans-Am
No, roller and flat tappets use the same cam bearings. All SBC's (even BBC's IIRC) use the same cam bearings.
You meant custom grind flat tappet cam right? Shouldn't cost ya more than $200 or so. Big split pattern due to the nitrous eh?
Car: 91 z28
well i had a cam spec'd out already, 241/249 dur @.050 .565/.580 lift on a 110 LSA i'm just going to go with that, accept in solid flat tappet, and get some new springs
Car: 1982 Trans-Am
This sounds like a mostly strip type of car? (or pure strip?)
I might recommend a tighter LSA, especially on a 385 motor. 107 is probably ideal, since it's a custom ground cam...
Car: 91 z28
i still want to be able to drive it an hour away to a track if need be, this cam will be fine
