ignition module
Car: 91 Z28
Transmission: BORG-WARNER T-5
ignition module
hi i had a new distibutor put in my car that came with the module on the distributor but when i took the new distributor out to have it swapped with another one the module on was not the one that came with the new distributor...it was gm module...i am just curious if i could tell if the gm module was the one from my car it has the numbers 048 0E24 in white on it and it has the the gm stamp then a yellow dot then the numbers 466 on it? i had it looked at by a dealer about 2 weeks after i had a guy put the first new distributor in it because it stated dying again ...the dealer said the gm module was on the distributor when they looked at it but im not so sure thanks
RedLeader289
05-28-2019 01:47 PM
Gunner242
12-25-2015 04:49 PM
