which cam to pick???
Old 03-30-2007 | 12:01 AM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
okay heres the scoop. i got 406ci with sportman2 heads.hooker 1.75 long tube headers, about 9:7 to 1 comp. a edelbrock dual plane manifold with a holley 750 double pumper. turbo 350 trans/with a tci 3,000-2500 stall converter and 4:10 gears. right now i got a comp magnum .501 lift and 292 duration camshaft. at the drags its real sluggish off the line, but runs 12.60 @111mph at the drags with 1.90s 60's. i want to change to another cam to get off the line better and take advantage of torque of the long stroke. there are two cams i looking at right now but don't know which one to buy. also i don't plan on getting a hydraulic roller , just to let you know . any help is appreciated.
cams i'm looking at right now to buy, but whick one???
Lunati Voodoo 227/233 duration .489/.504 lift
or
Lunati Voodoo 233/241 duration .504/.525 lift
or
your prescription!!!
1988 Chevy Camaro
406ci
1,90s 60's and 12.60s @111mph
Old 03-30-2007 | 12:06 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: which cam to pick???
The first one I had briefly. It's pretty small, it'd give you GOBS of torque in a 406, but it'd be a little tame I think.
The second one would be a good choice, that's the 60104 right? That should work great.
Old 03-30-2007 | 12:07 AM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
Out of those 2 i would go with the voodoo 274 (second cam), should run good in the 406. I put in the voodoo 268 (first cam) in my 383 and i wish i would have went one size bigger. Regardless im excited to start it up next weekend for the first time!
Old 03-30-2007 | 12:09 AM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
i think whats hurting you off the line is the converter and intake. you need to be more in the power range when you take off. making a cam change won't do any good untill you get the most out of the cam you have.
Old 03-30-2007 | 01:06 AM
Car: 1988 Iroc-Z
Engine: 5.7 TPI
okay now that voodoo 233/241 duration with .504/.525 lift cam. should i be worried about pistion to valve clearance. i have speed pro flat top forged pistion with the 4 valve reliefs. also i understand by changing my converter and going to a single plane would make my car run better , but i shift at about 5500rpm and its a street/strip car. i would rather take advantage of the torque produce by the long stroke. but thanks anyways.
Old 03-30-2007 | 12:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
No, you shouldn't have to worry about piston to valve clearance. I'd check it anyway though. Just rotate the motor over by hand a few rotations before firing it up.
junkcltr
08-03-2019 12:12 AM
Street Lethal
04-30-2019 01:14 PM
Below Average J
Members Camaros
23
11-18-2015 11:03 PM
camaro71633
09-01-2015 11:24 AM
Fronzizzle
08-09-2015 02:15 PM
Quick Reply: which cam to pick???
