i need chevy 350 eng. rebuild specs
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
i need all the specs for rebuilding a 350 like oil all of the oil clearences i know i have these somewhere just cant seem to find them does anyone know of a good book or where they may be posted online thank you
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: i need chevy 350 eng. rebuild specs
I used my Helm manual for my car, as well as "How to rebuild your small block chevy" by David Vizard. That was a good book. Some of the clearances are spec'ed with your new parts, or online. ie, piston clearance and ring gap will go with your intended usage, and choice of pistons and rings. etc.
Eric-86sc
08-24-2015 09:01 PM
NinjaNife
08-23-2015 11:49 AM
