Lil' Oil Filter Chart
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I have done alot of searching lately after I noticed that the old trusty AC Delco PF1218 I have run for years is now smaller and want to switch to a different brand possibly now that the car is almost running again. I put together this little chart to help organize what filters cross reference with the 4 most common AC Delco oil filters used on most any Gen1 SBC & BBC from what I found. I left Fram out as I don't use them and from what I can see most gearheads don't any longer. Aside from that if you see any errors, or other good filter alternatives please post up.
I did as many cross reference checks on each individual oil filter manufacturers website to try and verify that these are correct and as accurate as possible.
The only list I am not 100% about is the PF1218 list. I am not all that sure that all the other filter manufacturers have updated their cross reference #'s to the new design on the 1218. Just a FYI.
Re: Lil' Oil Filter Chart
fram is cheap i never run them, not any better than pennzoil
i still have found the larger 1218 at local farm supply stores
still are some more i need to go snag up
when those are gone ill run napa ones
good luck
good luck
Hotrodboba400
12-10-2019 07:07 PM
89 formula TPI
09-07-2015 11:06 AM
