Need help calculating DCR
I am building an engine right now and I can't figure out how to calculate dynamic compression
Here is the specs
383 stroker
10.94 to 1 compression(static)
4.03 bore and 3.75 stroke
cylinder head =65cc(afr 195 elim)
piston head(flat top forged speed pro with 2 valve reliefs)=3.4cc
gasket thickness=0.015
gasket bore=4.10
deck clearance=0.035 piston down the hole
Rod length=5.7(I am using stock 350 rods so is this correct?)
This is the one that stumps me
Intake Closing Point (degrees)
ABDC @ 0.050 lift plus 15 degrees=???
I am using the 280XFi cam, part number CCA-12-367-4
Duration at 050 inch Lift: 236 int./241 exh.
Advertised Duration: 280 int./290 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.552 int./0.547 exh. lift
Lobe Separation (degrees): 113
Can anyone help me to figure out dynamic compression??
Here is the specs
383 stroker
gasket bore=4.10
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What a bunch of BS, I can't find the cam card on comps website. If you have the cam in hand, you have the cam card?
I don't use the ABDC @.050 +15, I just use the intake closing point as is. I think that's more accurate.
So if you can find it, use that number
I was going to plug it in for you at
http://kb-silvolite.com/calc.php?action=comp
With 62* (as a pure guesstimate), 10.9SCR came to 9:1DCR.
