Breaking loose head bolts.
Car: 86 Firebird
Engine: LG4 feedback controlled 350
Transmission: used to be T5 now T56
It sure would be easier to use an impact gun to break cylinder head bolts loose.
Can I do that without tearing anything up? (ie warping a head, jarring cam bearings loose, any other crazy thing I haven't thought of)
Car: 91 RS
Engine: 305 tbi
Transmission: T-5 5 speed
Axle/Gears: Stock
never tried an impact on them i just done mine the other day and i used a ratchet and a piece of pipe on it with some help from my dad or my wife.and the book says it is a good idea to take the heads loose in the reverse order of tightening.dont know that it really matters but that is how i have always done it.
Car: '82 Z28
I had to use an impact on mine because the engine stand rolled around too easy hehe. A friend of mine who's a mechanic always takes them off with an impact. Of course, putting things back together you'd want to use regular hand tools and torque wrenches.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i usually take mine off with an impact.. i put them back on with an electric impact.. set to 15ft/lbs initially then to 45-50.. then i torque wrench it..
Car: 86 Firebird
Thanks for the replies.
A dirt track racer I work with said he uses an electric impact gun to put his heads on too. Wow, I never woulda' thought.
355tpipickup
08-25-2015 12:54 AM
