Where to set timing
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Where to set timing
i have a 85 lg4 with a elderbrock performer and a non cc qjet, hedmen headers and 3" flowmaster exhaust and i have my timing at 12*btdc i was wondering if this was a good spot for the most power it seems ok here but i want to know if theres a better spot i had it on 8*btdc but changed it
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
As long as you have a non-CC distributor and are setting the timing at idle with the vacuum advance disconnected, that's a good place to start.
How does it run?
How does it run?
Car: 86' Trans am
ya i got a non cc dist.. it runs pretty good just loking for some more power
Car: 86 Camaro
I'm running 12 degrees on our car and it's worked well there. We're running the torker manifold and street avenger carb, Lunati cam with regular hei ignition. Take off just blows with the 2:73 gears, if you're looking for more power, that's a direction you might want to look.
dan
dan
