Centerbolt Adapters?
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
I saw them on Ebay before. Basically they allow you to bolt normal Valve Covers to Centerbolt heads.
I want to buy some Sheetmetal valvecovers, i dont like the centerbolt ones they have out there. So i would like to buy the standard covers and then use the adapters on my stock heads.
This would also allow me to keep the same valvecovers when i get some better heads.
If anyone knows where i can find some, can you please post a link?
Thanks!
Thanks!
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
summitracing.com has some
Car: 87 IROC-Z28
Axle/Gears: Ford 9"
oh wow, you are right. Thanks
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I strongly recommend that you stick with the center-bolt valve covers. The reason why GM changed to center bolts is that they elimenate oil leaks. I'd rather have a so so looking valve cover which does not leak, than a better looking valve cover that can leak.
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
They also make some nice fabricated center bolt covers too. I would also suggest to stick with center bolt covers as well.
sreZ28
10-22-2015 08:21 AM
