Oil smells like gas
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Oil smells like gas
I broke my new cam in the other day so I changed my oil today. I drained the old oil out and it smelt like gas. What could cause this? During the cam swap I installed a new fuel pump. Could the new pump be faulty? Also while I was breaking the cam in, we noticed fuel coming out of the carb and base. Maybe that is related to why I have fuel in my oil.
Timing won't put fuel in the oil.
And before somebody else feels tempted to throw the other universal superstition scapegoat out there, it's not the EGR either. Sounds to me like you have a defective carb. Not too hard to figure that out... pour enough raw fuel down in a motor, to the point that it doesn't all burn, some of it is bound to get in the oil. Especially if it leaks when it's not running; like if it just sits there and empties the fuel bowls into the intake.
Try another carb, or fix that one so it doesn't leak, and see if it's any better..
Also, see my signature for helpful advice on troubleshooting.
Car: Forrest 91 t/a
Engine: 5.0 tpi w/underdrive/accel,full 3"
Axle/Gears: 3.73 pos
Timing will cause fuel to be pushed back up into the intake manifold and time ing will f**k up a cam which at that point could let fuel into the oil by way of the valve that may have stuck open do to the "broken cam". I'm sure he tried to start it after the cam broke.
that were i was a common from
Meanwhile, he said he "broke in" his cam; not "broke" it. Not that that has anything to do with a leaky carb dripping fuel into the motor.
"Timing" has nothing to do with it.
You REALLY need to read my signature.
Car: Z-28
Engine: 355
Axle/Gears: Stock
This may not be related, but when I built y firt engine I used Molly rings that for some reason did not "broke in", so I have combustiona leakage. I have high oil comsuption, oil look dirty and did smell like gas... however I never had the blue smoke at the pipes!
Hope this helps!
Hope this helps!
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
did you use a stock pump or a high performance?
if its a high performance pump & you have a new carb, before you mess with it check the fuel pressure. i have run into a few high performance mechanical pumps that produced more pressure than the carb could handle, some as high as around 10 PSI at idle. if the pressure is too high, an adjustable regulator should take care of it. if its a stock pump or an old carb, then do like sofa said.
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
Ive had this problem of fuel mixing with oil before. in my case the fuel pump was the culprit. also make sure the fuel pump bolts are nice and tight.
Car: 83 Z-28
Engine: LG4
Navy8125
08-21-2015 09:32 AM
