Hot tank with cam bearings
I got a 350 block hot tanked and the person who hot tanked it left the cam bearings in the block, I found this out months afterward so what can I do now?
You should remove the cam bearings, check all of the oil passages to make sure they are free and clear, and then put new cam bearings in it. If the motor is running and in the car and you not having any problems I might just leave it. But then you will always be wondering about if it is ok.
Car: 84-88 Pontaic Trans Am Convertable, 88 S-10 350, 89 S10 2.5L
Engine: 383 - 475 hp 485 ft lbs
Transmission: WC T5
Axle/Gears: 9 Bolt
your cam bearings will be toast, ive done this before, its no big deal as long as you replace them.
Car: '88 IROC-Z medium orange metallic
The solvent in the tank will distroy the bearings or anything aluminum not to mention is ruins the solvent. If the motor is running and the bearings were never replaced then someone is lying to you.
The motor hasn't been rebuilt yet. I was just wondering if the block would be fine after I removed the bearings that were hot tanked with it. Seems like it'll be fine once I replace it. Thanks.
theshackle
03-05-2017 06:37 PM
ambainb
04-25-2016 09:21 PM
