Oil Pressure
Car: Chevy IROC - Z 86'
Engine: 5.7 TPI
Oil Pressure
I just swapped my 305 TPI for a 350 TPI in my 86 IROC and my Oil Pressure gauge is broken, is there another way to check the oil pressure, without relying on the gauge.
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
myn idles 25-35 psi on Stock gauge and when i give it a good amount of gas it go's to at least 50+ and sometimes of the gauge if i really go for it
Car: 1989 Camaro RS, 355, holley 650dp
Engine: flow master headers, 3" exhaust
Axle/Gears: stock
On the 350 block right behind the dist, there is a screw in sending unit, that is the oil sending unit depending upon the gauge or idiot light is the type of sending unit to buy. I know a person can buy a temp oil pressure guage fairly cheap, it will screw in to test pressure. hope this is what you're looking for.
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
There is also a port on the front of the motor by the timing chain cover that might be a little easier to get to. I picked up my mechanical oil pressure tester from Harbor Freight for $5.
Car: 1991 Z28
Engine: 383
Oil pump squeezes oil from the pan and pushes it to the oil filter then to the oil galleys and to the different parts of the motor. Different clearances will change the oil pressure, as well as the pump obviously. There is a spring in the pump itself that will open when reaching a certain pressure that lets oil recirculate back into the pan and keeping the oil pressure in check.
