running on 7 cylinders
okay, so my 84 z28 overheated earlier this week. the heater core hose had one of those flush/fill kits on it and it blew off. ever since then i can't get it to run right. I've checked for spark on all cylinders and they've all got spark. but when i pull the #3 plug wire the car doesn't show any change. i've replace the plug and the plug wire, but like i said i'm getting spark. what else should i check? thanks
Car: 87 pontiac fiero
Engine: 2.5 liter
Transmission: 5speed
Axle/Gears: dont care.
same problem
hey i have the same problem.. my 83 trans am over heated last week and then it sounds like 7 cylinders, and when i unhook the #3 plug wire it doesnt sound any different..but im getting good spark on that plug, but mine also, makes a knocking noise.. plz help...
1 Post
Car: 92 Camaro RS
Engine: 305 TBI
Do a compression check. If that cly. is lower that the others then you have a bad valve or leaky piston.
alright thanks...I gotta run out and buy the compression checker.
damn, I was hoping for an easier fix...maybe click my heels together 3 times and say "there's nothing like a good running car, there's nothing like a good running car, etc."
alright thanks again and i shall report back tonight
NinjaNife
08-23-2015 11:49 AM
