Question about port/polish heads
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Would a machine shop be able to port and polish heads.Is porting and polishing heads a good thing to do?
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
yes, in fact you could do it yourself. if you gave some more info on your setup (carb,tpi,tbi,heads etc) then people might respond. anywho porting is easy, but time consuming. carbide bit and a bit of oil would do the trick. you should do a bit of reaserch first before you go ahead and do it thought.
porting and polishing just makes the intake and exhaust ports bigger. that exuals more power. pretty simple
equals
equals
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It's a good thing to do, but paying a machine shop $80/hr to do it is rediculous. By the time they're done, you've paid as much as new high perf heads, and have less performance out of them. It only makes sense to do it yourself.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
do it yourself.. its a good experience as well.. and later on, if you get the hang of it, let the word spread and have people pay YOU to port their heads.. money in the bank..
Mickeyruder
09-02-2015 02:45 PM
NinjaNife
08-23-2015 11:49 AM
