One piece or two piece seal????
1 Post
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
Does any one have any pictures i need to no which one i have and im not sure???????
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
You should be able to get the casting number from the engine block & look it up on mortec.com...
Received 1,721 Likes
It has nothing whatsoever to do with EFI. There are plenty of 350 blocks with 2-pc RMS that came with FI on top of them. And even 283 and 327 ones.
Look at the back of your block where the crank comes out of it. If the crank is PERFECTLY round, and there's a big cast aluminum plate or housing sort of thing back there, it's a 1-piece.
If the crank has a funky shaped flange on it that looks sort of like a counterweight for some odd reason, and there's nothing else back there besides the block and the oil pan, then it's a 2-piece.
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
gta892000
09-16-2015 12:37 AM
