How to Clearance a Crank Scraper?
Car: 1992 Camaro RS
Axle/Gears: Stock
Alright, I bought an oil pan from Canton Racing and it has a built in crank scraper (welded to the side of the pan). I'm just wondering how the hell am I supposed to clearance this thing. Could I use clay or something? And how much room should I leave between the crank and scraper? Thanks for any help. And if no one knows, I'll just grind the damn thing off.
![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Received 1,771 Likes
Easiest way is to bolt something thin and stiff to the oil pan bolts on that side; something like real thin clear plastic (probably the best), or cardboard; clearance THAT to the crank; then transfer that pattern to the real thing and cut it out with a die grinder or tin snips.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Make a template from posterboard. Trim as required. When you get it the way you want it, transfer to the scraper and cut as required.
Typical clearance is 1/16".
I don't use one in my engine. I don't even use a windage tray. My oil pan has a baffle to keep the oil in the sump and the oil level is low enough that it's far below the crank. 7 quart pan with about 6 quarts in it.
skinny z
10-05-2015 06:23 PM
