Whats going on
Car: 87 Camaro Bertalina
Engine: 2.8 V6 MPFI
Transmission: TH400
Axle/Gears: Stock
Whats going on
My 87 camaro ran out of gas today then i went and got gas and put gas in but left my radar detector on and locked the keys in the car with the keys in the on position. so i get back 6 hours later with gas and i jump the car off and then it took for a min then quit whats the problem
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Engine: 2.8 V6 MPFI
Transmission: TH400
Axle/Gears: Stock
I turned the car off but left it in the on position with gas in it already. So I went and tried to jump it off. It worked for a min then quit so now it does not have any power or anything
Car: 1985 Z28
Transmission: 700-R4
Axle/Gears: 3.08
Engine: 2.8 V6 MPFI
Transmission: TH400
Axle/Gears: Stock
I tried to give the car battery juice by using my truck to start it. But if it is not the battery then what could it be
Take your battery to an autozone near you to have them test it for you. Might have taken a dump on you. If that checks out, I would assume it is the alternator, but why would that decide to crap out just because you left your car in the on position?
Engine: 2.8 V6 MPFI
Transmission: TH400
Axle/Gears: Stock
I am going to try and charge the battery and see where that goes but if that does not work then im going to try the alternator
Engine: 2.8 V6 MPFI
Transmission: TH400
Axle/Gears: Stock
I charged the battery and it turned and then it backfired like a shotgun. So now what are your thoughts on the problem of the car now.
Car: 1991 Z28
Engine: 383 TPIS Mini Ram
Transmission: D&D Perf Viper/GM T-56
Axle/Gears: 3.73's Eaton Posi
How about some more info on what the engine is and what type of induction system its running. If it backfired like a shotgun you have more problems than your charging system. But seriously I cant make an educated guess on a problem unless you tell us more about what the car is.
Engine: 2.8 V6 MPFI
Transmission: TH400
Axle/Gears: Stock
Car is a 2.8 v6 and has Multiport fuel injection. what would it take to change out the charging system.
