General engine question...
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 RS
Transmission: Auto w/ evil shift kit; not my doin
Axle/Gears: It has a locker; not my doing
A chevy 350 has a 4" bore and a 3.48" stroke, i think that a 3.75 in crank and a 4.030" bore makes a 383. What makes a 400, or even cooler, a 427 sb? Also, is it possable to put a 4" crank into a 350? I'm just looking for good combonations.
Thanks.
Thanks.
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A 400 is a 4.125" bore with a 3.75" stroke.
A 427 is a 4.125" bore with a 4.00" stroke.
A 350 block with a 4" stroke is a 402.
Any combination that involves using a non-stock stroke will usually require some clearancing of the block. The longer the stroke, the more modification is generally necessary.
Car: 89 RS
What type of mod is req. for a 350 w/ a 3.75" srtroke? Does that mod differ for the 350 with a 4" stroke?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Look up "383 mods". Capscrew rods, small base circle cam, clearancing a bit on the block, etc. Some/all of these are needed. Kinda depends on the case.
4" stroke is not really possible on a stock block, as far as I know.
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I saw this, and want to try this in my car, but everyone says the max bore for a L98 is .060 over. This goes to bore 4.155, and has a 3.875" stroke. They say they used a stock block. *shrugs*
417ft/lb@2000RPM
420 Cubic Inches: L98 motor
Lingenfelter 420, from his book- Modifying Small Block Chevy Engines.
3.875" stroke Callies crank
Oliver 5.875" rods
11: 1 compression, custom forged pistons.
Used a Bowtie engine block
Comp Cams mechanical roller cam: 236/244 @ .050, .549/.549 lift, 110 deg lobe sep, 1.5 roller rocker arms by Comp Cams.
Lingenfelter ported AFR 190 aluminum heads
SuperRam intake, base, and 58mm throttle body, controlled by DFI using 36lb/hr injectors.
543ft/lb of torque@4500RPM 525hp@5500 RPM417ft/lb@2000RPM
As you can see from the numbers above, the motor is a torque monster. The combination of the large displacement, smallish heads, high lift roller cam, and the intake system make big block torque in a small block package. This motor computes out to a 113% efficiency at the HP peak, which is an indication of how well matched this combo is.
Last edited by TheScaryOne; 11-08-2006 at 05:54 PM. Reason: Table looked like garbage
Axle/Gears: 3.27 BW
But it's using a 3.875 stroke. Not a four.
4.155*4.155*4.00*6.282=420.260
But it's listed as a L98 engine mod. I might just have to buy the book and find out. :/
Edit: Ignore my smart assed math. I completely didn't notice the question above.
