Which coil for HEI, White or Yellow
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I have noticed that there are two types of coils available for coil-in-cap HEI disributors. What are the differences between the two other than one has red and white wires, and the other has red and yellow wires? Mine came (used) with a red and white wired factory type coil so I asume that the red and white is all I am supossed to run. Yes/No?
I've used them interchangably and not had a problem, although I'm sure there are differences in the coil as far as it's windings and such. If in doubt, go with the same color wires just to be safe.
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
wow i've used so many different coild i never paid attention to wire color...
in my experience, there should be zero difference, nothing can be worse then stock, so you cant hurt it....
