LT-1 A/C cycles too fast
Old 10-29-2006 | 08:50 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I have installed a 1992 Corvette LT-1 in my 87 IROC. I used the corvette's compressor, and new 87 camaro parts for everything else. A local shop charged it up with R-134. The compressor will run for maybe 7 to 10 seconds and then cylce off.........the air blows cold inside the car.........but i've never had a car that cycyled so fast- it just seems wrong. The shop has looked for leaks and says all's well- pressure is just right..........has anyone else had this problem and do you know of a solution- I have also changed the pressure cycle switch twic with brand new ones........ Thanks
Old 10-29-2006 | 10:09 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Gotta be low on freon, which is why your cycling. Only reason it would cycle that fast
Old 10-30-2006 | 08:28 AM
hotrodln's Avatar
Engine: Lt1 in IROC
well the shop says no..........it's got as much as they can put in it........I will try my own guage- you know thte ones that come with the recharge kits........and watch how it behaves..........
Old 10-30-2006 | 08:55 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Depeding on the ambient temperature, interior heat load, etc, It MIGHT be completely normal. On a 80* day at idle, my Dual A/C unit cycles every 15-20 seconds and blows ice cold, it is not low though. Rough rule of thumb is to take a gauge reading on the high side, it should be around 2x ambient + 50*, obviously the more air flow across the condensor and the larger the condensor the lower it will be. Don't forget that the compressor can cycle on the high side cut-out as well, that is BAD!
Old 10-30-2006 | 10:02 AM
hotrodln's Avatar
Engine: Lt1 in IROC
"high cycle cutout" is that the smaller switch in the line near the battery? I pulled the plug off of that one and the a/c wouldn't run at all, then I jumped it and ran it and it was back to the usual short cycle. I have also ONLY run this a/c system in sept and oct and it has not been hot at all around here........
InfernalVortex
04-20-2021 12:31 PM
jrdturbo
03-31-2016 03:58 PM
2012sergen11
10-13-2015 08:38 PM
92rsvortec350
19
10-09-2015 10:39 AM
mcfastestZ28
10-01-2015 12:23 PM
