How to start a car after letting it sit for the winter
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I just installed a new 355 in my Z28 I have broke the cam in but I havent driven the car at all. I need to give my buddy his carb back that he let me borrow so I wont be starting my car until probably april or may. I there any thing special I need to do when Im ready to start it 6 or 7 months from now after sitting for so long ??
Car: 90 IROC-Z
Fill the gas tank and put STABIL or somesuch water inhibitor in.
Use a properly mixed antifreeze in radiator.
I'd put a few drops of oil in each cylinder through spark
plug hole if you're unsure when you'll be firing it up.
Remove the battery and trickle charge each month to keep it fresh.
Park on a concrete or tarmac surface if possible if not protect the under carriage.
Throw a breathable cover over car to protect from uv and
crude.
crude.
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
I actually had a less complex method then what sofakingdom mentioned for my car after 10+ months of sitting. Put some fuel in it and turned the key. The fuel had either evaporated, or "evaporated" into my crack-head uncles gas-can, one of the two..
my freakishly good generic "everstart" battery was still charged somehow. I even used it through-out the course of it sitting (after several months through winter) to start another car that was having a charging problem.
I guess its different for every car. Though you shouldnt have to go to any great lenghts if it was still in working order when "rested".
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i used to leave my car sit all winter, it took me 2 years to realize i was getting nasty flat spots in my tires and thats what was giving me bad vibration at 90 and above in the spring, now i leave the batt disconnected and take it out for a spin once a month, with no heat , i get dressed up and its nice and smooth
Car: 1984 z28
Engine: 355
But do I want to but synthetic in my motor now all I have done is broke in the cam. I heard Im suppose to stick with regular oil until i have about 500 miles oon the motor.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Your right, you technically shouldnt run the motor on synthetic until the rings are fully seated. But i think for this purpose you should be fine, all you have to do is run it for a few minutes to get the oil around then shut it off.
