aluminum head serial number
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
i have aluminum heads but dont know what they are.. the serial number is 117977 or 17977 i forget which one it is an cant see it since they are installed
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
ooookkkkkaaaayyyyy.
How about the brand, or the company you bought them from, perhaps the intake runner volume that they advertised or something?
Or if stock, the casting number, which is stamped below the rocker arms on each head...
Car: 1985 Iroc Z
Engine: 383 carbed
there is no other numbers or name on them.. my engine builder put them on.. an hes an idiot an didnt know what they were but they made just alil under 500hp.. so i wasnt complainin
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Well, usually its cast or inscribed into the head somewhere... usually either on the side, between the exhaust ports (if its cast on) or inscribed into the front machined surface where the alternator would be bolted on.
Also, sometimes there is something cast somewhere under the valve cover. On my cousin's Edelbrock heads (on a Ford 390) it has the Edelbrock "E" logo (looks like a big backwards 3) cast in. Maybe your heads have something there too?
Worst case, you could always check out a few of the manufacturers catlogs and see if you can find a matching part number.
Car: 1985 Iroc Z
Engine: 383 carbed
ive looked through summit an jegs online an still havent figured them out.. i think they are old TFS. but im not quite sure
ambainb
04-25-2016 09:21 PM
IrocZ'85
08-17-2015 06:24 PM
