double hump/461 heads
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
i found a set for 500 bucks already machined and ported, cut for bigger springs. any way question is, are they worth it? or should i buy a set of vortecs
Car: 1988 Trans Am GTA
Engine: 350 4BBL
If you are after cheaper more modern (possibly not worn out) heads the vortecs are a better buy.
1 Post
Car: 91' Pontiac Firebird
How "ported" are they? was it a professional port job by a real porter who knows what he's doing, or some guy in his garage with a die grinder? There is a huge performance difference between the two.
Car: 1984 camaro
Axle/Gears: 3:42
the heads were ported by a local speedshop, i think i forgot to mention they have valves and everything except the springs and associated components.
Received 1,862 Likes
Those heads won't fit one of these cars, because they don't have the accessory bolt holes.
You can't use them. They would be the wrong choice, even if they were free.
Keep looking.
Keep looking.
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
