witch cam do i choose PLEASE HELP
Car: i have a 2003 ford zx2 and a 1989 f
Engine: 350 tuned port, 4 banger on the Z
Transmission: 700r4 poop loser
Axle/Gears: 3.23 standard ...one tire fire
im looking for the better all around cam .. and my friend says the extreme cam will bogg down on a carbed system
Xtreme Energy XR276HR-12 Hydraulic Roller Camshaft
Operating Range: 1800-5800
Duration Advertised: 276° Intake/281° Exhaust
Duration @ .050'': 224° Intake/230° Exhaust
Valve Lift: .503° Intake/.510° Exhaust
Lobe Separation Angle: 112°
or
lt4 hot cam
This hydraulic roller cam is for service only for all V8 engines with roller camshafts. The duration at lash point in degrees (intake/exhaust) is 279/287; duration at .050" tappet lift (intake/exhaust) is 218/228; and maximum lift with 1.6 rocker ratio (intake/exhaust) is 525/525. Valve lash is zero/zero and lobe centerline is 112 degrees.
please help i want one of the 2 but i dont know whitch to choose .... many many opionions wanted
or
lt4 hot cam
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Well, we need to know a little more than that. What's the weight of the vehicle? Approximations are ok. 305, 350? What kind of exhaust setup? Heads? Rear gears?
Last but not least, what are you looking, in expectations from this car? If you're looking for more Low end power, I'd say stick with the LT4 cam, the other will make you more peppy in the higher end, but if you have a numerically low gear ratio, it may be a bit of a dog.
