BRAND new engine leaking oil from dipstick and smoke off valves covers???
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi
I instaled my brand new rebuilt engine in my car...i had oil leak everywere. When a fix a leak somewere, is start leaking from an new place...after a while i fix all leaks but now its leaking from the dipstick and white smoke is leaving the valves cover higher i rev the engine the more it smoke's. the guy told me that it was the rings that needs to seats at the right place. but after 100km still does the same...i did a compression test and 1) 200 2) 190 3) 190 4)190 5) 195 6) 190 7) 190 8) 190 ...seems good compression? dosnt smoke oil from exhaust...
what can it be?
what can it be?
Car: 1992 Camaro RS
Axle/Gears: Stock
That white smoke from the valve covers is most likely oil leaking out somewhere and burning off on the headers, intake manifold, etc. If the dipstick continues to leak I would suggest checking/replacing the seals or just getting a new one all together.
ok
well the white smoke is comming off the pcv valves holes and oil cap hole...smoke from the inside of engine...
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
You might want to check the pcv system to make sure its working properly. If you are getting new leaks on the fresh engine it could be from too much crankcase pressure b/c of the faulty pcv system.
still getting this problem
with 2 breethers no pcv....does that with everything removed too!!!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that screams excess crankcase pressure. put back in your pcv and try that.
Or did you plug something in the block?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
That`s blow-by... there something wrong with the ring size or they are broken, the smoke is combustion burning the oil off the cylinder walls and pressurizing the crankcase, one or two other possiblities is the ring lands, they could be broken and not supporting the ring or the rings could have been installed wrong (i.e. upside down) and yes you still could have compression with this problem
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
as much as 200 psi ?
say what ?
is it stock rebuild or ?
normal compression in a stock engine is 150
and highest to lowest reading has to be within 20%
if you have all kinds of pressure and gases coming out of the valve cover and other places then i would run away fast
sounds really bad
not good,
good luck
say what ?
sounds really bad
not good,
good luck
NBrehm
08-26-2015 12:49 AM
R3500
08-17-2015 01:16 PM
Street Lethal
08-12-2015 12:33 PM
