Stupid Injectors
Car: ws6
Engine: ls1
Transmission: m6
Stupid Injectors
So I brought my car down the shop 2day cause the service engine light came up..and I test out all my injectors and get this the 4 on the passenger side are good, 1 on the drivers side is good, but 3 are also junk on the drivers side. The car has a rough idle and is skipping Is this job a pain in the ***?
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If it has stock runners on it with a little work, all you have to do is pull the plenum and lift the injectors out from the rail.
SLP runners, at least one runner will have to come off to do the same thing.
Its fairly easy, do a few searches and work slowly and surely.
DO NOT PINCH THE O RINGS
later
Jeremy
later
Jeremy
Car: ws6
Engine: ls1
Transmission: m6
Ive never had a problem with this car yet and the other day i find out i need a new mass air flow unit, new distribuator cap and plugs, new injectors. I really hope the bad injectors didnt mess up the computer...
Car: ws6
Engine: ls1
Transmission: m6
I brought the car to a shop 2day and this guy says total cost is going to be around 1800!!! rrrrrrrrrrrrr. Also what kind of injectors should i get for better performance, and what size? thanks
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
I would keep the stock # size that you are setup for, if its a stock chip then stick with the 21# injectors, best I keep hearing are the Ford SVO injectors, I'm gonna try out a set for my miniram.
All the stuff you listed can be done yourself, which would save you a lot of money. Email Cruzinperformance.com and see what he thinks. You might not need new injectors.
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
very easy, not the most basic, but its at the beginner level...
take the top plenum out... pull the 4 fuel rail bolts, pull the injectors and rail out, remove bad injects, replace... reverse directions...
thejimsterz28
09-15-2015 04:37 PM
