My engine made me vomit!
Litterally
This is what I found when I took the intake manifold off to do the cam.
What do you guys think?
also when I first put my finger in and looked at it I threw up :? :shock:
thats from the heads
that looked like this
carbon?
carbon?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Looks like somewhat normal sludge in the coolant passages, and carbon in the exhaust crossover. It could all use a good cleaning, though.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if you're feeling up to it, (i'd recommend it), bring in the intake manifold, and heads, to a machine shop, for hot tanking. You'll need new head gaskets, and a bit of time for removal, but the peace of mind is pretty good there. Also it's a good idea to put on new valve seals while you're there.
That should turn you into a believer of regular preventive maintenance. That coolant went far longer than it should before a flush and change. The oil looks like what I used to find with the old Pennzoil "GT" oils - lots of sludge and varnish.
Yep its pretty discusting, I should go show the guy I bought the car from, considering, I only drove the car about 300 miles in a year.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yeah normal coolant sludge there....thats what happens when ya dont change it.
And please please don't put Dexcool in it. Dexcool is notorious for that type of sludge, seen it all too many times. It's really quite bad stuff, I always recommend to all my customers that they convert it over to universal coolant, and every time we perform a coolant flush, we do. We never fill Dexcool into a car.
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
I have heard too many stories of Dexcool being used in a generic coolant system, it turns to a gel. I wouldnt use it in the first place, dont know it, dont trust it.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
looks about normal for a higher mile SBC...
the sludge in the engine is from running crappy oil and not changing it often enough.
the coolent is the same thing.. its from not changing it, and/or running mostly water.
