Finished cam break-in. how do i check for worn lobes?
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You could be really **** and measure the lift at the valves, and see if they are all the same.
Just check the valve lash, make sure none loosened off or whatever, and run it. If it runs fine, it probably is.
Fronzizzle
03-18-2019 08:29 PM
ambainb
04-25-2016 09:21 PM
