Crane hydraulic roller lifters which ones to get?
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
motor is 87+ block with oem rollers, i need some hydraulic roller lifters for my 383 build, camshaft is ligenfelter's 74219 (219/219 .525"/.525" @1.5) cranes part number CRN-10530-16 seemed to be the one i needed till i found this one CRN-10535-16. its says that the 10535 is "Required for use with camshafts having greater-than-stock lobe lift or reduced base circle diameters." summit doesnt seem to know the answer to which one i need, and the 10530 is $189 while the 10535 is $519. both are for oem roller blocks. anyone know which one i need?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The 10535's have a taller body to stay above the stock alignment dog-bones. Higher lift cams often have a reduced basecircle to provide the additional lift. Talk to Ligenfelter about whether you need them with their cam.
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Avoid the reduced base circle cam, if possible. It will significantly increase the cost of your engine build-up.
Car: 91 Z28
after talking with ligenfelter. the 74219 cam can be used with stock like lifters, there is no need for the taller ones.
how so?
KO1
16
10-15-2015 05:00 PM
skinny z
10-05-2015 06:23 PM
