What does valve float sound like?
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
wow, this might be even the most unique question i've ever seen on the boards but it stands.
I assumed i had good enough springs for 7000rpm with my cam.
234/244 duration @.050, .520/.544 lift...
Well only while under load, the motor makes a small high pitches rattling noise, i assume its the motor atleast, sounds to be coming from the engine bar.
Usually you'll only hear it on the 2-3 shift as 1-2 hits at 5500rpm, and 2-3 waits till 6000rpm.
its a very low level, high pitched rattle sound. Very hard to describe.
Would this sound like valve float?
Car: 85' TA
Engine: 355 Carbed
Originally Posted by ede
sounds more like preignition or knock to me, try a change in timing or octane.
and that was my olther guess, ya know what they say, always expect the worst...
i already use 93 octane... timing curve may definately need a changing...
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Car: 85' TA
Engine: 355 Carbed
ok yeah the car was still pulling like there was no tomorow, even at 6k but that rattle made me wonder... I still smoked that LS1...
I just got an MSD ProBillet Distributor so, i'll be fixing my timing curve...
What would be my best way, knock would be from timing too far advanced, dont think my timing was way too far advanced, and i only run 93 octane.
I run 13* at idle with a stock HEI, and let it rip its full mechanical afterwards. Guess it throws too far... I'll find out soon enough...
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
