305 cam swap
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
305 cam swap
ok since i have my heads off to get screw in rocker studs instaled i figured id upgrade my cam since its not the best for what i want nad ive gotten a lot of greif from ppl about it. i was wondering what some on here would suggest. i want to make max power 6k and lower mor like 5500k and a slight bump would be nice ive looked at these two and was wondering what some might have to say bout em any one used em? Brand: COMP Cams
Product Line: Competition Cams Dual Energy Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,500-5,750 RPM
Intake Duration at 050 inch Lift: 211
Exhaust Duration at 050 inch Lift: 221
Duration at 050 inch Lift: 211 int./221 exh.
Advertised Intake Duration: 265
Advertised Exhaust Duration: 269
Advertised Duration: 265 int./269 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.465 in.
Valve Lift with Factory Rocker Arm Ratio: 0.442 int./0.465 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: CS 265DEH-10
CARB EO Number: D-279-3, D-279-5, D-279-6
Quantity: Sold individually.
Notes: For 1987 and earlier carbureted Chevy 262-400.
Camshaft, Hydraulic Flat Tappet, Advertised Duration 265/269, Lift .442/.465, Chevy, Small Block, Each
Brand: Lunati
Product Line: Lunati Voodoo Camshafts
Basic Operating RPM Range: 1,000-5,000 RPM
Intake Duration at 050 inch Lift: 207
Exhaust Duration at 050 inch Lift: 213
Duration at 050 inch Lift: 207 int./213 exh.
Advertised Intake Duration: 250
Advertised Exhaust Duration: 256
Advertised Duration: 250 int./256 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.437 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.454 in.
Valve Lift with Factory Rocker Arm Ratio: 0.437 int./0.454 exh. lift
Lobe Separation (degrees): 112
Camshaft, Hydraulic Flat Tappet, Advertised Duration 250/256, Lift .437/.454, Chevy, Small Block, Each
well any help and or advice will be greatly apreciated sorry for such a long post i tryed just posting the url but it didnt work
Brand: Lunati
i had a crane blue racer in my old 305 with 214*/224* @ .050 .442/.465 lift on a 112lsa. this cam pushed my car to a 13.03@103mph. now, this cam is not the only thing responsible for that. the car had quite the converter and gears. i think that this cam will give you exactly what you are looking for. a bit of a bump at idle with shift points at 5500rpms. summit has the exact same grind under the Summit Brand. you can get cam and lifters for $69.95. p/n SUM-K1103. the item description only has it making power from 2000-4500 for some reason, but i know that cam made power to 5500rpms.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I think you'd be happier with an Xtreme Energy series cam, something like the XE262 or XE268. I don't have any direct experience with the Voodoo cams, some people say they've tried them and like them, but I have this mental block against them since they chose that name for them. Regardless, that's a pretty mild one you listed.
Can we assume you're getting new valve springs to match the cam while you're at this?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think the second one listed, would work well for you. I have the 60103 "best 268 cam ever", and it works quite well in my 350.
Ironically I have an air freshener that looks like an alien, little puffy guy, hanging from the rearview, you poke him to emit the smell. Apparently you have to poke him with a sharp object to get him to start to smell. hmmm.....
Engine: LS1/LQ4
You gotta follow their recommended break-in procedures. Or, coat the lobes and lifter faces with ARP thread lube when assembling.
(And, avoid getting one of their quality issues era cams.)
Engine: LS1/LQ4
I didn't say "assembly lube". . .
Anyway, I know it's hard to regain trust when it's been broken. It takes a long time to earn a good reputation, and only minutes or seconds to ruin it.
Personally, I have only had one Comp cam, my current XS282. From what I've seen on the Board, however, your experience seems to be extreme.
well i know they say you get what you pay for but i dont want to spend too much on this motor since im starting my 383 in weeks but i want to get this 305 back together to have something to still play around with until the big motor is done and that will get a lil better milage and performance that the cam i have now. when the original machince work was done springs were put in to handle about 480 lift so i should be ok on springs. i do plan on new gears soon and mabey a stall from a 4.3 s10 or i may wait cause i am ultimatley doing a 5/6spd swap. like i sad though i just want a lil better power but lower and some bump to make it nice when i go cruising. what about that summit cam that mw66nova mentioned? ive thought about summit cams but they list weird power ranges and what not.
trust me, for $70, it's a steal. the cam works really well.
scroll down to the bottom of this page, there is a video of my car with the old combo. you can see if you like the way it sounds. this car had hedman longtubes, dual 2.5" pipes with a flowmaster knockoff muffler and an h-pipe.
http://d1378976.u41.j-angel.com/subpage.html
im thinking i will go with the summit cam but was wondering if it would be worth while to upgrade to 1.5-1.6 ratio roller tip rockers like the stamped ones summit offer?
Car: 99' Z-71 85' T/A
Engine: 5.3 305
Transmission: 4 auto 5 man
Axle/Gears: stock 3.73 auburn posi
Re: 305 cam swap
hey guys im just gonna jump in... 85 t/a hedman headers performer rpm intake edelbrock carb, 305 l69, t-5, 3.73 gears, my car runs good. never been to the track but did 13.8 on the dyno. i was almost set on the extreme energy.... but now im scared to. i need to do my heads anyway i get power to 6k rpms and pull studs regularly. they have a full install kit for like 330 on ebay... and 100 for stud install. i wanna hear everyones 2 cents about what cam with my setup.
Re: 305 cam swap
Wow man this thread was from 2006 lol your a little behind. I ended up going with the summit 1103 cam and loved it I run that cam in my k10 pickup now also.
