car stumbles/loses power briefly when accelerating
not sure what's going on. i've got a 91 5.7 and when I get on the gas a little it will lose power or stumble very briefly and then jerk forward a little later. annyoying as hell. onece in a while i'll hear a pop from the exhuast but that's not often.
so far i changed the wires and fuel filter but i don't know what's going on. im using 91 octane.
Car: 1989 Camaro Iroc-Z
Axle/Gears: 2.77 Posi
My car dose the same thing sometimes ( 1989 TPI 350 )
Usually when i dont let it warm up for like 5 mins it will do that, ill go to take off and it stumbles bad and then jerks and goes like nothings wrong. The plugs and wire havent been changed in 2-4years so im guesing it could be that for me? But im interested to see what people say about it because it is very annoying.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Check your tv cable tension. When I did my shift kit, I didn't adjust it optimally, and I got a studder in the middle of 2nd.
Mine will do it in Park also, if i try and give it gas it gets all pissed off and stumbles, if i let it warm up 5 mins or so shes fine.
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
novaderrik
08-10-2015 12:44 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
