Hydra-Rev kits, are they necessary???
1 Post
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Well, I was just curious about it because I will be running a hydraulic roller camshaft with my new engine combo. I was browsing through the AFR site and found that they make them. I understand the theory behind why you'd need to use them, but are they really necessary on a street engine? I don't plan on running it up past say 6200 RPM, but would this be like having some added insurance? Here is the info...
Hydra-Rev
Hydra-Rev
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
6200 RPM you shouldn't need them. Normally when your lifters pump up at 6500RPM + your power level starts to drop off, with the rev kit it puts springs on the lifters to prevent that, so power keeps going up. (Assuming cam and springs can handle it.)
You don't need it.
You don't need it.
1 Post
Well, that's what I thought, but wasn't sure. I don't know what it is with me, I have a problem spinning V8 engines up past 6000 RPM. Get me in some dinky little import though, and I'll crack it all the way up. Who knows, maybe it is just a part of my subconscience trying to blow that b!tch apart
1Aauto
Sponsored Vendors
02-08-2017 03:09 PM
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
88SS6SPEED
11-11-2015 07:05 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
