What oil do you guys use?
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Yes, I already 'd. I think most of you like Mobil 1. This guy I met at a car show this weekend said he picked up a tenth using Royal Purple. Which do you all prefer? What weight?
I have a 1991 GTA with a 350 TPI.
Thanks,
Bill
P.S. What about rear differential fluid? I'm going to need to replace it when I get the rear fixed.
Thanks,
Bill
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I have never run anything too fancy in my cars, at best it got Quaker sythetic blend 10w30 but then again i dont run the thing at the track hitting 7000RPM consistently...
As for the rear, is it a posi?
They can be very picky and sometimes just a regular mineral oil with the posi additive is better that a full sythetic top of the line!
One again in my rear (open) ive just used a mineral 75w90
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
quker state synthetic....10w30 in the beast.
run same in my explorer and she has 161,000 and uses no oil.
1 Post
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
In my 1998 Trans Am I run Mobil 1 fully synthetic oil. It also has Redline fully synthetic D4 automatic transmission fluid, and Redline fully synthetic 75W90 in the rear diff along with some GM limited slip additive to keep the chattering down.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
in my 87 rx7 I use mobile 1 5w-30 in the motor. tranny has mobile 1 75w-90 I think?
the honda is using mobile 1 5w-30 in the motor and also uses 5w-30 mobile 1 in the tranny.
1 Post
I've heard of some guys running 5w30 in their 3rd gens too. Any benefit over 10w30?
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
A lot of people over at the v6 board will suggest 15w-50 mobil one for the v-6's also.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Other the fact that its slightly thinner and may free up a pony or 2 if your lucky... No, not really...
You pick an oil that is suited best to your engine, If its a brand new engine with nice tight clearances 5w30 should be fine. if its an older motor and clearances are getting pretty big you may get some knocking and burn more oil than you would if you went with a thicker oil.
My old motor was rattling a bit and after an oil swap to 20w50 it purred again
Car: 2005 BMW 545i
Engine: 4.4L N62B44
main reason I use the 5w-30 rather then the 10w-30 is cold start up
the first number is how the oil acts when cold and since here in idaho we can have some cold times when I Start my car figure it couldn't hurt too much. it isn't really going to free up any horsepower being when the motor is warm 10w-30 and 5w-30 are going to be the same viscosity.
again the w number is the cold number
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
30 weight Rotella T diesel oil here. For the price and the added zinc you can't beat the good ole Shell Rotella T.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Well it looks like ill be dumping in the $1/gallon stuff for a while
Just sitting around tonight so i thought what they hey, ill go for a rip and see how it runs against the Grand Am again. Well it was pulling real hard off the line for once and with 0 detonation (for once) then at about 3500RPM in 3rd i heard some hard knocking (not deto!) and let off. pulled off to the side of the road only to have a nice cloud of blue smoke trailing me and some lovely knocking and rapping coming from the motor.
Oh well, another 350 bites the dust...
Car: 2005 BMW 545i
Engine: 4.4L N62B44
that's it this world is comming to an end. first we have 57kid pawning off his wares and now red devil you have become part of this cult?
so in return I must start a cult
1 Post
Where can I get Amsoil or Redline? Also... what oil filter do ya'll use?
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I've been told that the domestic oils have a better molecular composition than the overseas stuff. So I use Pennzoil (Pennsylvania oil). I think quaker state and a lot of other off the shelf stuff probably comes from the US.
But I stay away from 'Walmart's finest' cheap crap. That stuff is probably shipped strait from IRAN
I have seen Quaker State Q high horsepower pour out of a car with 10,000 miles on it and look extremely good for the milleage; impressive to say the least.
Car: Tree Huggers
Engine: Do Not
Generally, the Walmart and no-name brand stuff, is just repackaged brand name stuff. Not sure on the formulations though. :shrug:
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Not me, I use only the best oil.....$0.79 a quart from DOLLAR GENERAL, We are smoking now!!!!!
j/k, I use Valvoline 5w-30, I wouldnt put that cheap crap in my lawn mower, which I found is fun to use seafoam on (neighbors hate the smoke).
ambainb
04-25-2016 09:21 PM
Navy8125
08-21-2015 09:32 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
