Help..Black water/condensation from tail pipe.
Old 04-25-2006, 02:13 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
I have a 91 rs with a 3.1 158k .At start during warm-up I get black water dripping from tail pipe.... Car is all stock, what might cause this??
Old 04-25-2006, 02:31 PM
TGO - 10 Year Member
Received 1,861 Likes on 1,418 Posts
Running the engine might cause that.
The normal products of perfect combustion are water and carbon dioxide. During warm-up, combustion is less than perfect, so some of the carbon makes it out unburned.
So, there you go: water, which condenses into a liquid; and soot.
It is completely normal.
Once the engine warms up, combustion becomes more complete (no soot), and the water stays a vapor because the exhaust is no longer cold enough to condense it.
Old 04-25-2006, 02:50 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Thanks, the stains on the driveway are ugly...
Old 04-25-2006, 03:09 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Yeah, it happens, but it is completely normal.
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
LT1Formula
10-08-2015 08:34 PM
Quick Reply: Help..Black water/condensation from tail pipe.
