How many rpms in a 400ci crankshaft???
Hey guys!!! ok this its the deal
i have a friend a he just build a 400 ci for drag racing, and he told me that he is using the original crankshaft.
He told me that he is going up 7000rpms? ???
is it possible???
cause i knew that you can only go 5500 rpms with that stock crankshaft
am i wrong???
is it possible???
am i wrong???
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
valve train limits your redline, as in, how high it "will" rev. How long it'll last at that RPM is defined by the stability of the bottom end.
It won't last very long.
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
He's right.The stock cast crank in my 406 only has about 200 passes down the strip on it,mostly with a 200hp shot of juice.It'll never live.I know mine's only been to 8500RPM.
so if i go 6000 and less it is going to be ok???
Car: 1982 Trans-Am
mm, yea, what was I thinking? Clearly a stock 20 year old crank should be good to 600+ HP and 8500RPM, duh! I wonder why the aftermarket even makes crankshafts for that motor, seeing as how the stock ones are obviously perfect.
I guess i'll stop shovelling my in this thread then.
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
As long as everything is balanced well, and he's got some lighter slugs on there, it might be ok. What kind of balancer? A good one will help a lot.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Received 1,848 Likes
I'm not going to touch this one with somebody else's 10' pole (my own sure isn't that long...)
I once learned a valuable lesson:
"Never argue with an idiot. They will drag you down to their level, and then beat you with their greater experience."
Seems like there's lots of people on these boards nowadays that make up this stuff, all about how they get results totally outside the realm of ordinary mortal experience. Maybe that's why alot of the old regulars with lots of BTDT quit coming here; they got tired of being in the middle of some kind of ****-length match? I don't know that, just a guess.
And how the hell does that
Car: '88 IROC-Z medium orange metallic
A stable valvetrain and good harmonic dampening are going to let you rev higher, not the material of the crankshaft. If he used a stock crank in a "race" motor then chances are that he cheaped out on the valvetrain too and he's probably got a stock 400 damper. So don't expect that thing to hold together for long if he's twisting it higher than it was made for.
I'm willing to bet that his motor quits making power waaaay before 7000 rpm anyway, so shift your car where the motor makes power and drive around his dumb a$$ while his car falls on it's face. If he used a stock crank in a "race" motor then chances are that he cheaped out on the valvetrain too.
Angel, I wasn't talking about you....
I don't hold you responsible for what your friend claimed. Which I don't believe, any more than I believe the post I was actually referring to. So, to answer your question:
A stock 400 crank won't withstand many times past 6500. I think the last one I broke from doing that, the front piece of it is still sitting on a table in my brother's house.
That one broke (as they most often do) right where the #1 & #2 rod journal meets the throw. That particular one broke in such a way that the engine actually continued to run, and I was able to drive it into the garage, pull the motor, and put a crank kit in it.
The deal with RPMs isn't something like, it'll go to 6613 RPMs, but it'll dissolve to shrapnel at 6614 RPM. Rather, the effect is cumulative; a crank might live forever if it never passes 5000 RPMs, or live out a normal service life of 100,000 miles or more if it hits 5500 RPM once a day, or 25,000 miles if it hits 6000 once a day, or 2000 miles if it hits 6500 once a day, or 20 miles if it hits 7000 once a day. Now, what's an acceptable RPM limit under those conditions? Right... it's up to the owner; and it's determined by the use the motor is being put to.
You can ALOt of cams that are A WHOLE LOT BETTER than that one, as far as just being a better cam goes. Whether some cam or other is better FOR YOUR COMBO is a whole other question though. That would depend on what heads you have, what exhaust, gears, converter, transmission, car weight, use you put the car to, money you can spend, and a whole long list of otehr factors. It's not like you can go I've got a 406, so X cam is the "best" for me. There's more to it than that.
Originally Posted by ME Leigh
Do you have your tach on the 6 cylinder setting. Let me get this right, your saying you can turn your stock crank 400 to 8500 rpm with no problems?
YES.It's not frequent,but it has been to 8500 more than once.Anyone that doubts me is more than welcome to come to Ozark Dragway in Rogersville,Mo. and put their money where there mouth is.
Oh,and sofa,your name fits better than I thought.Does my crank have a fuse or something?I was just curious,as you seem to know more about my engine than I do.Maybe that Chunk of crank you have says something about the quality of the balance job you have.
thanks man
ok this is my combo
400ci, 5.7 rods, 0.20 pistons, stock vorteck heads, vorteck manifold, 650 cfm edelbrock, and the 214-224, long heathers, 3.43 gears, 400tranny, sotock converter(for now),
You are a stooge. I dont believe you, nor does anyone else. The funny part is, you make yourself look stupid, so we dont have to call you names or help you along.
I like it that way!!
Read my signature.
I'll enter you in my next write-up for the Journal of Irreproducible Results.
Oh, and be careful what you ask for, in case you get it. I still have a piece of property after all these years near Shirley Ark. Maybe I'll come down and check out this one-of-a-kind wonder with a 6-cyl tach you've got there.
Read my signature.
If you guys are so confident that my engine cannot live at 8500 for brief bursts,EXPLAIN.Because Super Chevy say's it can't?!
You or LJ are welcome to come witness it any time you'd like.If I'm a stooge,it would amaze you "experts" how many Grand American Late Model stock cars in this area are running these crankshafts that I obviously don't realize are junk.Lord knows,stock cars don't abuse crankshafts.
Those guys you mention are probably running an aftermarket crank. Unless in your part of the states the air contains special compounds that gives cast iron cranks the properties of an aftermarket forged unit. Perhaps you found this laying in a barn somewhere? lol.
OK,let's get something straight,then hopefully let this die.I'm only carrying this on because I can't stand to be called a liar.Goes back to an old lecture from Grandpa when I was 6.
I never said I had 200 passes at 8500RPM.I said I had 200 passes on a stock 400 crank,mostly with nitrous,and it has been to 8500.Going through my logbook tonight,I find that I lied a bit.I have 179 passes on this engine,143 of them on juice.I have not recorded RPMs,but it has been to 8500 a FEW times.This is not a shift point,it is just something that has happened on accident a time or three.No,I don't think for a second that it would last 200 passes at 8500 RPM.But yes,I will stand behind my statement that properly balanced and lightened stock cast crank is capable of more than anyone gives it credit for.I use a very light rod/piston combo.
I am in the midst of dropping a 468 into my car because of a recurring head gasket problem.But if anyone comes here to see a stock 400 crank do 8500 RPM,give me a week's notice,and yes,I'll swap it back in with fresh head gaskets to prove it's been there before.
Now,someone please lock this thread,I've obviously sent it so far off subject that this question will never be answered accurately,and I apologize.
One last thing,PLEASE don't classify me with the Duntov cam TBI 305 guy and the COPO 427 guy,I LIKE it here!
cool thank you all guys
1 Post
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Take an engineering course and you can understand how any component is rated. The teacher will hand out a box of paperclips and pass them around the classroom. Everyone is instructed to bend their paper clip and to record how many tries it takes to break the paper clip. Now the results will usually average the same. While some paper clips will break with more bends some will break with less and then you average it out. The general rule of thumb is to stay below the average. So if you apply this reasoning to a crankshaft you will find that some will break sooner some later but there will be an average. If a crankshaft is rated for a certain rpm or horsepower you can bet these tests were performed to attain that data. So in conclusion just because someones crankshaft has been able to handle more abuse than average doesnt mean the one you get wont break with less abuse.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
is it possible???
am i wrong???
is it possible???
am i wrong???
This particular crank lasted just over 1800 1/4 mil passes, 75 1/8mi passes and 5-6K street miles over 2 yrs. Shifted consistantly at 6000rpm, once in awhile I'd shift it at 6500 to play the bracket racing game to get ahead of my dial, and I have at least 20 passes at 7000rpm shift points only gaining .04 over shifting at 6000rpm. So unless your buddy has a huge monster cam, big compression to support the big duration cam his pwr band will definatly be under the 7000rpm mark. It boils down to how well the block was put together IMO since by everybodies thoughts my motor shoulda fragged the first few months I ran it LOL!!
Used a stock damper too which I believe was the ultimate casue for failure since the crank snapped off just behind lower cam gear and reacked havoc
Originally Posted by IHI
Angel, check the sig and you can see what I ran. Stock short block with stock OEM parts that were just reconditioned.
Originally Posted by ljnowell
I dont what you say at all. I have a 350 w/ stock crank that regularly sees 6500 and has seen 7K. Niether of these stories come anywhere close to 8.5K though. Not at all.
ok thanx
Hotrodboba400
12-10-2019 07:07 PM
