stripped weight?
stripped weight?
fellas, what would you estimate the stripped weight of a 92 camaro RS 305 to be? IOW, what all can I remove and how much weight can i save. i'm not talking about going into frame and replacing suspension components for lighter weight ones, yet.... this is a future drag car (brackets) most likely, so about all the creature comforts can go.
stock weight is around 3200 I guess, with T-tops and everything stock in car. if i can get the weight down to around 2500-2700 easily ???? i might drop something kind of mild in there for now til i can afford a better build up this winter or later.
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
Look under the tech articles and you will find a list of mods to reduce the weigh tby about 250 pounds.
https://www.thirdgen.org/sheddingpounds here is the link
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Stock weight for most third gens is closer to 3500 pounds depending on the options.
Mine is a completely stripped down drag car. Fiberglass hood, all the glass has been replaced with Lexan including the T-tops. No interior. It can never be made street legal again. Anything not required for speed, safety or the operation of the vehicle is gone. With an aluminum head BBC and a full roll cage, race weight which includes driver, fuel etc, is around 3000 pounds. There's very little I can remove to reduce the weight any more. The next step would be to get some fiberglass doors. I'd love to have a race weight closer to 2800 pounds.
I never care what the car weighs by itself because it never operates without a driver. I estimate my weight at around 180 pounds but that's just a guess. The engine has to move all the weight down the track so total weight or race weight is what counts.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The early cars are by far the lightest, the latter cars the heaviest. My car right now weighs in a 3010 lbs. I have a stripped rear interior, no engine/computer wiring, aluminum heads, aluminum intake/water pump, PS and alternator only with custom lightweight brackets, lightweight aluminum lower control arms, panhard, and lightweight torque arm. I have a very short exaust with a very light muffler. Nothing to drastic but its still street legal and setup for Auto-X racing.
Damon
09-26-2015 04:29 PM
