Is it safe to sandblast a harmonic balancer?
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Just wondering, really... I plan on cleaning mine up quite a bit.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
i'd say so. but just think of how long it'll take you to get it really nice and clean, and perhaps painted, compared to a summit $59 one, that has engraved timing marks..... Same with the oil pan, I have no idea why I re-used mine
Car: 1992 Firebird
Engine: forged 357
Car: 1982 Trans-Am
wow that stuff is clean. pistons in your house? Mine were soaked in oil/grease to press fit the pins on, so they'd stink like crazy in the house...
well ok, but if it takes you a while to do it, then is it worth your time? My main beef was to be able to measure timing with only 10* visible on a stock balancer and tag. I didn't have a dialback timing light so I just bought the balancer you're looking at in your other thread.
Car: 1992 Firebird
Engine: forged 357
Yeah a 750 sqft apartment and I have a transmission and nearly a complete engine in my bedroom. You should see under my bed...
I cleaned everything in the parts washer before bringing it inside my house, so there's virtually no smell. The only smell you can faintly smell is spray paint from the transmission.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It will take all of 10 minutes to sandblast it properly and completely, and as a bonus, sandblasting also will NOT damage the rubber in the balancer. Sandblasting it would be the best way to clean it up. Just need to mask off the machined surface in the middle, where it slides onto the crank. You'll need to use duct tape, its the only stuff that holds up to sandblasting well.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
(something about the satisfaction of a V8 built in an apartment....)
Jeff Foxworthy: "Can you move this transmission, I need to take a shower".
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
750 sq-ft? What do you do with all the extra room? I've got 530. But then again, it has an attached 7 car garage.
Engine: 350 4BBL
Looks like it has already been sandblasted. I'd worry more about the hammer marks where it has obviously been pounded on the crank before.
(like the Cheezits box, brings back memories)
Car: 1992 Firebird
Engine: forged 357
And yes, it obviously has hammer marks. Are they "okay?"
Engine: 383 Carb
Transmission: 4L60
No, this is my house. It's just a matter of priority. All you need in your living space is enough room to eat, sleep, bathe, eliminate and copulate. Anything else is unnecessary.
Engine: 350 4BBL
I just did sandblast it in class today
Power steering fluid and antifreeze everywhere. Everybody had to wait for "cleanup on aisle 2".
monte87cortez
09-26-2015 08:10 PM
roysatikas
09-22-2015 08:15 PM
