Various wires/plugs, can these be removed?
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
ITEM 1 This wire goes through the firewall and connects to this relay/device thingy shown in the picture. What does this do? Can it be removed?
ITEM 2, 3 and 4....There are all plugs that come out of the thick wire loom on the passenger side of the firewall...these plugs do absolutely nothing...can i cut the ends off and cap them with a wire nut?
ITEM 5 What does this do?...can it be safely removed?...can i remove the tubes and plug the ends?
ITEM 6 These 3 (yellow, blue and orage) wires appear to be the power supply for the heater box....does that seem right?...if not, what wires shown in the picture would supply power to the heater box?
[IMG][/IMG]
[IMG][IMG][/IMG][/IMG]
[IMG]
[IMG][/IMG][/IMG]
[IMG][/IMG]
[IMG]
[IMG][/IMG][/IMG]
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
[IMG][/IMG]
[IMG]
[IMG][/IMG][/IMG]
[IMG][/IMG]
[IMG]
[IMG][/IMG][/IMG]
Car: 1988 SC Camaro
Engine: 305 TBI
Good Idea....I bet there are some wires shown in the picture that i don't need...but others i might...i hope someone will be able to identify some of them for me
Car: 82 Z28
Transmission: TH350
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
tahst what i always do, dont suspect something is wrong until it is, if something dont work, then you fix it, hook up what you think you need and leave the rest for if ya need it, afterwards cut all the excess out. makes it alot cleaner and you might give that old third gen a pound to loose. she'll love you a long time for it.
