Oil article in latest High Perf Pontiac Mag
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
Not sure if you guys read this or not... It's about camshaft lobe failure over the past 12-18 months in flat-tappet cam motors since the new API service classification with motor oil. Very informative read.
Here's a link: How To Understand The Slippery Truth About Motor Oil - High Performance Pontiac
The short of it is the new API and ILSAC classifications call for less Zinc Dialkyl Dithiophosphate (Zinc and Phosphates, aka ZDDP)) be blended into oil. These elements are anti-wear additives believed to cause catalytic convertor failure, so they are being reduced, without a good viable alternative developed yet. With the reduction of ZDDP, flat tappet cams are failing, and comp cams has even issued a disclaimer with their new cam shafts. Roller cams seem to be unaffected.
But many of our "stock" motors are flat tappet cams... and as HPP has documented As insurance, I added a bottle of STP 4 cylinder oil treatment, which has a higher content of ZDDP, according to the label. The 4 cylinder treatment isn't as thick as the old blue bottle... might try the blue bottle with 5W30 oil. The sad part is that all synthetics, in order to conform to the new classifications, also have less ZDDP in them as well.
It looks like yet another attempt to get older cars off the road. Just curious to see what the enthusiasts think about this one.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I wouldn't worry about stock cams. The slow, lazy ramp profiles on a stock cam are nothing like those on a modern high performance aftermarket cam.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Magazine articles are too limited to what they will tell you. For all the info you'll ever need on oil, go here.
http://www.bobistheoilguy.com/
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I'd have to question their example failure:
"Even with top-quality oil and routine changes, our Pontiac had developed a distinct exhaust "pop" under load. Since its cam and lifters were over 10 years old and had traveled several thousand issue-free miles in that time, we hoped to find something as simple as a rocker arm that needed readjusting. But once the valve covers and valley pan were removed, we found much worse--a severely worn camshaft lobe. With no real wear on subsequent lobes or lifters, it appeared we were victims of an oil-quality-related failure." (emphasis added) Why would oil only cause one lobe to wear? The oil goes to all of the lobes - if the oil isn't doing the job, they should all be worn. They either had a cam with a soft lobe, a bad lifter, or another engine-related (such as lube supply) problem. Being 10 years old doesn't change any of that.
From another picture caption on Page 3: "Both the cam and lifter were high-quality, name-brand units. Break-in and normal use included top-quality synthetic oil that met the latest standards." Did they use the synthetic during break-in? If so, DUH! (Not sure if this was the same cam they talked about on Page 1.)
One way to avoid an additive problem with flat-tappet cams is to use a racing oil. They don't have to meet the GF standards, so will keep the zinc/phosphorus content high. Of course, that always is brand-dependant, and they can change their formulas anytime they wish without notice. As always, "Buyer beware."
Don't paint with too broad of a brush here. If they aren't trying to meet the GF specs, that won't be the case.
Truck/diesel oils and synthetics still contain the EP antiwear additives (Shell Rotella may still, and Mobil Delvac at least does at last check). Your other options are full PAO synthetics, like AMSOIL or Mobil 1 (be careful which Mobil you buy), and/or Howards direct lube flat tappet lifters.
Car: '88 IROC-Z medium orange metallic
Penn Grade is another that has high Zinc values still. I use it on every new motor we break in just for that reason.
Engine: LS1/LQ4
Originally Posted by Vader
Truck/diesel oils and synthetics still contain the EP antiwear additives ... Your other options are full PAO synthetics, like AMSOIL or Mobil 1 (be careful which Mobil you buy), and/or Howards direct lube flat tappet lifters.
So, it's a great anti-wear oil, great storage oil, and coincidently, a great flat-tappet oil.
Yes, the reduction in ZDDP has been discussed on the BITOG forums. If you want oil with ZDDP, use Mobil1 Truck & SUV oil, or most any HDEO (diesel engine) oil like Rotella, Delvac or Delo. I also believe that one of the BEST aftermarket additives is Valvoline Synpower Oil Treatment (VSOT), it's add pack is very good.
GC (German Castrol, 0W-30) is supposed to be pretty good as well. I think Autozone carries it. Be sure to look for the "made in Germany" on the back of the bottle.
Thanks for all of your opinions guys. I know oil can be a hostile subject (like spark plugs and 02 sensors) but thanks for being polite and respectful.
Five7kid, I understand where you're comming from with the test subject in question... and I do think most any 10 yr old flat tappet cam in a push rod motor is going to have one of "those" lobes regardless of design. It's just... maybe I'm paranoid, but it smells a lot like the oil company crusher program in California a few years back.
Then again who knows?
82tabird
12-21-2015 10:22 PM
Thirdgen89GTA
08-25-2015 06:40 PM
Navy8125
08-21-2015 09:32 AM
