What valve covers for my TPI motor?
Car: 1998 Trans Am, 1992 Firebird
Engine: 402 LS2 stroker, 355 SBC
Transmission: T56 in both
Axle/Gears: 4.10 gear Moser 9", 3.27 9-bolt
We have a 92 Firebird that we swapped in an 87 TPI into, but the valve covers are very rough looking. Theyare some cheap chrome ones that look like crap. We are running the Crane 1.6 roller tip rockers and they hit the baffles, so we removed them. They work for now, but look absolutely terrible. I want to replace them with some new ones, but I want to get some that I can just prep, powdercoat red, and throw on the motor.
We're going to be installing a Holley Stealth Ram on it and it has a BMR 3-pt STB on it now. I needsomething that works with all of these.
I'd prefer a smooth cover, too.
Anyone know of which set I should buy that will work with my setup without any cutting, hacking, or bloodshed?
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Proform makes some already powder coated red I believe and they are taller with no baffles. Check out Jegs/Sumitt to see if those are something youd be interested in. I have the black wrinkle finish with red lettered ones...sit a bit taller and look nice...no baffles.
So the taller valve covers will work? I'll check Summit for them, see what I can dig up.
I'm not sure which color to go with, I have a powdercoating setup in my garage, so I'll probably just go with the chrome ones and coat them whatever appeals to me once the HSR is on it.
I'm going to be running a set of comp 1100 series roller rockers, so I'm in the market for some taller valvecovers as well. I had these in mind:
http://store.summitracing.com/partde...5&autoview=sku
They are black, plain, but still sharp looking, just what I was looking for. They also have a PCV provision which many of the others didn't have. My only issue is clearance, I heard some tall valve covers won't clear the alternator.
Car: '87 Trans-Am
Car: '87 Trans-Am
Sweet, any issues installing them?
Originally Posted by CreepingDeath94
Not really, they do sit a little taller though so the PCV/breather tubing that runs along them on that side as well as the engine electrical sits on top rather than snug along the bottom like it used to. Nothing major though, still looks good...just something I noticed.
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Are you using the 87 Belt set up? If you are using the a 92 alternator location you may have some issues with tall covers hitting the post on the back of the alternator.
https://www.thirdgen.org/forums/atta...g?d=1130212855.
Well......I ordered them already so I guess I'll have to see if I can grind down the back of the alternator. Damn, I figured something like this would come up that is why I hesitated
Transmission: A4
Axle/Gears: 3:23
Try them first. Creepingdeath didn't mention any problems. I had old style heads on my motor so the covers were slightly different. Update this post when you get them. I want to know if they clear that post. I might buy a set myself.
Definitely please update when you get them. I have the 92 belt setup on my motor. I'd hate to have that sucker hit the alternator post!
Car: '87 Trans-Am
I have mine in the same location and i didnt have any issues...I believe the bracket mounted on the header bolt not the intake...Ill have to double check and let you know. Hopefully this picture loads...
Car: Used to drive a camaro
Dart Tall Covers DO hit the alternator post. I had to shorten the post and use a thinner nut on the back of my alternator. I have Dart Iron Eagle heads and Dart Tall aluminum valve covers (ordered from Summit). You will have to do some sort of modification if you plan on using 91-92 alternators and tall covers.
My set-up looks exactly like his and mine plugged right in...no problems. Hopefully his will be the same...
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
NBrehm
08-25-2015 11:49 PM
