Dipstick
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Dipstick
Well the good old dipstick broke while taking my manifolds out. Just wanna know where I can get a good and affordable one that will fit my 1990 305. Thanks you very much fellows.
Engine: LB9, LB9
But see how does the oil readings work, wouldnt the different size ones read different oil levels?
Engine: LB9, LB9
well the only one I can currently find is in jegs and its mr gasket and it says 82-85 camaros but i guess it works.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I've been searching for one on my 87 roller roller motor and the only one I found is from Mr Gasket and the chrome plating makes it 0.008 larger diameter than the hole in the block!!!
The side the stick goes in IS the correct size (I don't know what they did)
Been sanding on it for a bit now and got it down to about .003 oversize and still won't go in.
The earlier sticks are shorter overall so look for the right one or measure it to see if it will work. Jyard is looking better to me than the aftermarket stuff.
Engine: LB9, LB9
This is getting to the point where I just want to sell this damn car. How the **** dont you make a dipstick for a damn 1990 305.........cannot even find a chrome one. I found this POS and it looks too small, looks like it would go too far into the block. or whatever the hell it goes in.
http://www.seffects.com/parts/SPT5726.htm
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
wow go to your local speed/race shop. say i have a small block chevy with a passenger side dipstick please order me one. thank you. $15 later you're done.
That IS the correct one
Don't know why its labeled those years. It does go into the block about 4".
The older ones are about 8" shorter IIRC.
Engine: LB9, LB9
local speed race shop is like 45 mins away because Maryland is gay and I am just fed up with the car being on stands for 4 weeks. So this one will work for me and give me accurate oil readings?
tyeo098
11-30-2015 06:27 PM
codeysabatini
11-10-2015 04:07 PM
