knock sensor and loud exhaust
1 Post
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Can your knock sensor be affected by a loud exhaust system ? I just put true duals on my GTA (crude home job that ends at the axle) and at certain RPM's one muffler contacts the bottom of the car which causes a rattle, could this cause my sensor to try to back the timing off ? The setup is only temporary until I can get a good single 3 inch system.
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
shouldnt....i believe the knock sensor only "reads" a certain frequency or a small range... i dunno if your rattle will produce the same frequency...
Chuck84TA
07-15-2016 09:05 PM
